It is currently Fri Aug 15, 2025 12:43 pm
 Post subject: Later days, Dremel!
PostPosted: Thu Oct 30, 2014 1:41 pm
Imagecant wait to take it for a spin!
 Post subject: Re: Later days, Dremel!
PostPosted: Thu Oct 30, 2014 2:01 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Now why did you need to go and post that Ed? I was just starting to feel content with my current level of tooling ;)
Doug
These users thanked the author Doug Balzer for the post (total 2): dofthesea (Fri Oct 31, 2014 11:52 pm) • James Orr (Thu Oct 30, 2014 2:49 pm)
PostPosted: Thu Oct 30, 2014 2:05 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I'm half way there, Ed!!! I've got the same laminate trimmer! gaah I think I'm going to have to give Tony K a call.
Alex
PostPosted: Thu Oct 30, 2014 2:40 pm
nice, I want one of those!
PostPosted: Thu Oct 30, 2014 3:15 pm
I got it from Sylvan Wells, 125$ shipped. Very solid precise unit, though I would like to replace the fine adjustment knob with a tele knob. He has more for those who want one. I've grown tired of the rinkey dink (though admittedly effective ) Dremel after 150+ rosettes. Now I just need to find some 1/4 shank downshear spiral bits...
PostPosted: Thu Oct 30, 2014 3:57 pm
I meant the router :) I've made more than 20 of those circle jigs over the years for sale.
Amazon for your bits or find a local machine shop supplier for end mills. Don't look for router bits, you'll pay too much.
http://www.amazon.com/Diameter-Shank-Fl ... A4HR47GM14
PostPosted: Thu Oct 30, 2014 4:18 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Whenever I do use a 1/4" router for small slots, I just use a brass adapter sleeve to reduce it to 1/8". Works great.
PostPosted: Thu Oct 30, 2014 4:48 pm
"Whenever I do use a 1/4" router for small slots, I just use a brass adapter sleeve to reduce it to 1/8". Works great."
+1
Stew Mac has them.
PostPosted: Thu Oct 30, 2014 7:10 pm
First name: Tom
Last Name: West
State: Nova Scotia
Ed:
If you are interested in 1/8" downward spiral, try roto zip bits, shorten them up to the length you want, grind new relief on the cutting edges and you have relatively cheap bits.
Tom
PostPosted: Thu Oct 30, 2014 7:50 pm
+1
Stew Mac has them.
yup
PostPosted: Thu Oct 30, 2014 10:41 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
precise bits and Elaire corp make 1/8" collets for most popular routers. Rigid? Not sure. Precision collets are much better than those inserts. I also posted a link for bulk buying of 1/8" bits (last 2 weeks). All of this will work with WK jig and improve ur work.
PostPosted: Thu Oct 30, 2014 10:57 pm
Since the ones Rod posted are only 6$, I'll try that first...
PostPosted: Fri Oct 31, 2014 4:02 am
First name: Tom
Last Name: West
State: Nova Scotia
Ed: I've bought the roto zip bits 16 in a box at less then $2 a bit.
Tom
PostPosted: Fri Oct 31, 2014 12:25 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Ed,
You will probably be OK. But, if after you cut your finer slots <1/16", and you notice wide spots after you insert purfling and sand back, then you might have an issue with runout. Unforunately, Elaire Corp does not make a precision collet for Rigid. Precise Bits does, and it's the same as the Bosch Colt. Maybe you call Elaire and ask if their Bosch Colt Collet will work on the Rigid? Other than that, precisebits has a good one, albiet expensive.
Elaire corp does sell a precision collet reducer that may be a good solution as well. http://www.elairecorp.com/colletadapter.html
Precise bits collet: http://www.precisebits.com/products/equ ... Kit!!!PG!!! (Bosh Colt Warning does not apply)
$6 a bit is high. I usually get them under $2 a bit.
Two flutes: http://drillbitsunlimited.com/Carbide-R ... 48900.aspx
Fish tail: http://drillbitsunlimited.com/Carbide-R ... 48900.aspx
This is the same guy that sells on Ebay (folks mention him in other posts here and on other forums). Reducing from 1/4" to 1 mm is a lot, and you will find like me, that these break a lot. So it can get expensive in a hurry.
Thus far, my favorite bits are fishtail, lightly used, 1/8" shank, 1 mm, 1/16, 3/32, 1/8
PostPosted: Fri Oct 31, 2014 1:18 pm
LuthierTools has those: http://www.luthiertool.com/binding%20cutter.html
Scroll dow, you can buy just the cutter, super high quality.
Old growth, shmold growth!
PostPosted: Fri Oct 31, 2014 3:59 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I must be missing something here. Don't you all find a 1/4 bit (not just the shank) a bit much for rosette work? I like any initial cuts I make to be much smaller and work my way in or out. If I make any kind of mistake, a small cut is easier to recover from. Perhaps ya'll are talking about something else... idunno
PostPosted: Fri Oct 31, 2014 4:02 pm
You're right actually, he want 1/4 inch SHANK not TIP.
Do they make 1/4 inch shank bits in tiny cutting diameters?
PostPosted: Fri Oct 31, 2014 4:18 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I do not know if they make them (the really small ones). I went to that site above and they only carry 1/8" (and oddly, one 3/16").
I fixed those links.
PostPosted: Fri Oct 31, 2014 6:02 pm
I like to use 1/32" bit to start with.....All 1/4 shaft size.
PostPosted: Fri Oct 31, 2014 8:25 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Rod, what do those 1/32 bits cost?
PostPosted: Sat Nov 01, 2014 10:19 am
I bought them years ago off a guy on eBay. I'll see if I can find them again.... If I recall they were about $3 each back in 2008 or so....
edit: Don't know what I was thinking yesterday when I posted that the bits were 1/4" shaft. They are 1/8" shaft....
I just did an ebay search and there are plenty of options.....
http://www.ebay.com/sch/i.html?_from=R4 ... l&_sacat=0
And I think this might have been the source I purchased from in the past. Qualitymachinery
Here's another source at a good price. Carbide Plus
Users browsing this forum: guitarjtb and 21 guests
